Adam Image Manager
Post your Miscellaneous questions here
Wmaalouli
Adam Image Manager
Post by Wmaalouli » Sun Jul 21, 2019 12:50 pm
So I am getting an error when I try to delete files from certain disks, whether CP/M or EOS, but it's not consistent. My system is a Win 10 laptop.
Here's one of the disks that throw an error. I am using the latest version from the Adam Archive.
EOSWORK.ZIP
(4.89 KiB) Downloaded 294 times
pearsoe
Re: Adam Image Manager
Post by pearsoe » Sun Jul 21, 2019 3:36 pm
The EOSWORK.DSK image is a non-standard EOS image and why Image Manager throws the error. The directory structure for an EOS disk should have at least 3 entries besides the volume label; BOOT, DIRECTORY and BLOCKS LEFT. All of these are missing in the EOSWORK.DSK image. If you generate new media in Image Manager or ADAMEM and use a hex editor to compare it to your EOSWORK.DSK you will see the difference. I guess I should edit to explain the problem rather than have it crash though.
If you have other problems, provide a step-by-step with an example DSK or DDP image. It will help isolate the problem quickly.
Wmaalouli
Post by Wmaalouli » Sun Jul 21, 2019 3:48 pm
Hmmm... I created that disk using Virtual Adam and was using it normally. It looks like it got corrupted after trying to open it with AIM. Same thing seems to have happened with the disk attached, which contained a copy of the 2010 DDP files...
2010 copy.zip
(81.76 KiB) Downloaded 273 times
Post by Milli » Sun Jul 21, 2019 4:09 pm
Wmaalouli wrote: ↑
Is it an interleaved disk image or non-interleaved ddp image?
Wmaalouli
Post by Wmaalouli » Sun Jul 21, 2019 4:35 pm
Non-interleaved I think
Post by Milli » Sun Jul 21, 2019 6:46 pm
Wmaalouli wrote: ↑
That would probably be the issue - if it is a ddp image then its possible Eric's software wont work.
pearsoe
Post by pearsoe » Sun Jul 21, 2019 9:09 pm
Found the source of the corruption I think. I'll upload AIM 1.1.1 soon for testing. The software should handle both interleaved (DSK) and non-interleaved images (DDP).
Wmaalouli
Post by Wmaalouli » Mon Aug 05, 2019 1:19 pm
It seems that the AIM insists on converting pure binary files into .com files regardless of the original file's extension. It also seems to be adding a 128 byte "header" to the converted files.
Is this an expected behavior?
Post by Milli » Tue Aug 06, 2019 6:31 am
When copying to pc or to Adam image?
Wmaalouli
Post by Wmaalouli » Tue Aug 06, 2019 6:56 am
Copying from pc to Adam.
