R80 roms!
Re: R80 roms!
Here you go. I went through the trouble of splitting these to update an old console a while back.
Re: R80 roms!
Just for the benefit of the un-initiated like myself, what are the R80 roms?
Re: R80 roms!
They contain the system OS kernel (EOS) and the SmartWriter ROMs.
Re: R80 roms!
Got it. Why do you need them? Have your roms been damaged?
Re: R80 roms!
Thanks! Tekman
Wmaalouli, A person heard that I was looking for a Adam console so he stopped over with a R79 Adam. The console works great so I wanted to upgrade it to a R80. Tape drive needs some work. Funny how I was down to one working console now I have way to many.
Jim Walters/Walters Software Co.
Re: R80 roms!
How can one tell which rom version is in the console?
Re: R80 roms!
When the ADAM boots to SmartWriter press <CONTROL> + R and the revision will show on screen under SmartKey IV.
Re: R80 roms!
I highly recommend that you read thru "The ADAM Survival Guide" that is available in PDF from numerous Adam sites including the Archive as it will bring you up to speed on the basics. The NIAD and N&B newletters will as well, but there is a lot of them to peruse.
Re: R80 roms!
So much to learn, so little time....
